Building a DIY Static or Rotary Induction Generator
Garry Sainsbury
Joined Oct 21, 2016
4
Hey Guys
Newbie here
i picked up a 7.5kw induction motor from a online classifieds in hope of turning it into a 3 phase generator for welding etc.. i was originally going to power this motor with a smaller electric 240volt motor using a V drive belt
now someone has mentioned to me if i run this motor in delta 3 phase it will produce 600-700 volts when i really only need to produce 415v 3 phase
can u guys with electricial knowledge look over this and tell me what the go is?
I'm in Australia our normal voltage is AC240v or for commercial it is 3 phase 415v
Garry Sainsbury
Joined Oct 21, 2016
4
Thanks Albert
I tried today to spin up the induction motor but only got 3volts and 3.8volts i also used 12 volts to energize the induction motor
tcmtech
Joined Nov 4, 2013
2,867
And type and how big of welder do you expect to power with this using what size of drive motor? o_O
