Buck Converter MOSFET Output Voltage distorted (PWM)
Rango356
Joined May 2, 2019
5
The input to my buck converter MOSFET switch is a PWM signal with a certain duty cycle. However, upon observing the voltage waveform of the MOSFET, the voltage is a bit distorted.
The input to MOSFET (PWM signal) and output of MOSFET is observed and pictures are attached.
1. PWM input to MOSFET -- Blue waveform
2. MOSFET output voltage (Duty Cycle) -- Blue waveform
Can anyone please explain why is there a difference in the attached 2 pictures. The duty cycle should be same and it shouldn't be distorted post coming out of the MOSFET.
Rango356
Joined May 2, 2019
5
hi 356,
Please post a circuit diagram of the Converter.
E
It is actually a university assignment but I am confused as to why they both differ. I am attaching the picture of the circuit.
The first picture (PWM input to MOSFET -- Blue waveform) in the question was measured at 8 (Vpwm) and the 2nd picture (MOSFET output voltage (Duty Cycle) -- Blue waveform) was measured at 12
Rango356
Joined May 2, 2019
5
Since is for school think about what's connected to the drain of that mosfet and what effects they can have...
one theory that I was working on was that there is an inductor connected to the MOSFET drain, but I am confused. The inductor influences current.
The rise time and fall time of the current gets impacted due to the presence of an inductor. But I have the waveform of the MOSFET's voltage.
I don't know where I am going wrong.
38,924
Remember there is stray capacitance to ground at the connection between the MOSFET and the inductor.
What does an inductor and a capacitor form?
Can you look at the inductor current?
Rango356
Joined May 2, 2019
5
if i am not getting wrong, (and I really appreciate your help)
As the PWM signal goes HIGH - MOSFET switch is closed, inductor current starts to increase linearly until the point that the inductor current is maximum (i.e. inductor acting as a short-circuit).
During the time when the inductor current is increasing linearly, inductor voltage depicts unwanted spikes.
I can't seem to understand the reason behind these spikes.
Rango356
Joined May 2, 2019
5
an LC oscillator circuit?
if I am not wrong,
An oscillation network is formed and leads to parasitic oscillation of a MOSFET. The ringing voltage between the drain and the source during turn-off could return to the gate terminal through a positive feedback loop via the gate-drain capacitance Cgd and cause the gate voltage to oscillate.
