Buck converter minimum operating temperature
Tony Wright
Joined Mar 18, 2019
I am an electronics novice and am looking for a 12V/5V converter that is proven to operate down to -25C. I want to power several security cameras that need to keep working during a Canadian winter. Most of the ones I have found on Amazon and Ebay claim -40C minimum but a reviewer has stated that one of these would not "switch on" below -20C. I contacted Drok (the Amazon supplier) who said the -40C was a mistake and -20C is the minimum. Many of these converters look alike with different names on them so who knows who makes them, they may be all the same but most claim -40C.
I want to distribute at 12V with converters at each camera but I suppose I could install a single larger converter and distribute at 5V, however the converter would still be subject to -25C
Any suggestions about suitable converters?
Tony
Uilnaydar
Joined Jan 30, 2008
118
I play around with alot of those cheap Amazon/Ebay converters. Those environmental specs are suspect to say the least. If you REALLY need to operate at -25C or below. Head to a Digikey/Newark/Mouser company and pay the extra for an open frame DC/DC.
From Amazon, I've done OK with Meanwell... just look VERY CLOSELY at the labeling before using them at extremes. I've been burned by counterfeits before. For extreme conditions I get my Meanwell parts from Digikey.
ArakelTheDragon
Joined Nov 18, 2016
1,366
If they say -40, they will be ok until -30. Every converter should have a few grades of temperature. It can be produced for Automotive/Industrial/Military. Check the datasheet for which are possible. I think LM2596 is good.
Tony Wright
Joined Mar 18, 2019
Thanks for the suggestions.
My project is a solar powered security camera system with five cameras outside and the solar controller/batteries in an unheated shed. I have already bought the cameras that run on 5V assuming it would be a simple matter to put a small 12V/5V converter ahead of each camera either outside (if they were waterproof) or in a small vented box. I then heard of a possible -20C temperature limit which is not low enough for southern Ontario. The max distance from the 12V batteries to camera is about 100ft so I am reluctant to run 5V wires from the shed because I don't know how the cameras will react to variable voltages. This means a central open frame converter is not really practical.
I think I am simply going to get what appear to be better quality converters with good reviews that claim -40C minimum (some say -20C).
Can someone explain what is meant by the following statement that I see on some data sheets.
"Operating temperature: -20 °c to +60 °c (Industrial grade), -40 °c to 80 °c (limit) "
Tony
pmd34
Joined Feb 22, 2014
529
I think it means that the industrial grade components will operate "happily" from -20 to +60... but an odd case of -40 to 80 is OK but not suitable for continuous operations. A bit like the maximum voltage ratings of a component - "it shouldn't self destruct but we dont recommend you run it at this."
Ya’akov
Joined Jan 27, 2019
10,322
Tony
Perhaps you can use a buck converter to get the 12V down to ~7V and linear regulators at each camera.
kubeek
Joined Sep 20, 2005
5,796
Not really, most stuff that is rated -20 will have trouble starting and operating at -40. At low temperatures usually things like oscillator not starting happen, but it should not have an effect on reliability or destruction of the device.
