Great, do post soon if it works or doesn't!My circuit is just sitting there, waiting. No Excuse, but it will be tested (and we'll see if it works).
I will later. It's a matter of time, but I may have some free soon. I don't need money, but components would be good. If you have any 0603 resistors, caps, etc. then it will save me the cost of getting them. I can then buy the more expensive components (mosfet, switcher, etc.) myself.Tom,
If you can find the time.
Ill donate the money.
You put a lot of time and effort into this, and I would like to see it built.
Get a Bill Of Materials together.
The working revision is a few posts back, I'll post it again later if I've made some changes.I am also interested in this.
Just need to know which schematic is the "working revision".
I'm also interested in a Buck/Boost that is essentially a "Joule Theif", but to run a 5W Cree White LED from a Full CR123 cell to dead. See Surefire's "Backup" LED flashlight for the idea, but the two brightness settings from tailcap taps aren't needed (First hit, High, 2nd hit within 1sec = dim, after that, next hit is off). Only requirement is using all SMD components, 1" diameter PCB or less, height can be up to 3/4".
I will, when I get the BOM. At the moment, I'm at college, and I have no way of transferring the schematic or BOM off my laptop.Post or PM what you need to complete it, and I'll see what I have, and get you what you need.
Here's the BOM:No hurry, friend.
When you get the time.
C1 100n 0603
C2 22u 16V 1206
C3 100n 0603
C4 330n 0603
C5 100n 0603
C6 100n 0603
C7 1u 16V 0603
C8 4.7u 16V 0805
C9 22p 0603
C10 100n 0603
CONN1 DC power jack CUI PJ 202 - for DC input
CONN2 any 2.54mm 2-way pitch connector, prefer MTA100, can also solder wires to board - for battery input
CONN3 any 2.54mm 2-way pitch connector, small headers only - for PWM input
CONN4 any 2.54mm 2-way pitch connector, prefer MTA100, can also solder wires to board - for LED output
CONN5 any 2.54mm 2-way pitch connector, small headers only - for external ammeter (as a voltmeter)
D1 Any 1.0A Schottky Diode in SOD123 (e.g. RB160M)
D2 Any 1.0A Schottky Diode in SOD123 (e.g. RB160M)
D3 BAV99W SOT-23 dual diode or any SOT-23 diode with pin 1 as anode and pin 3 as cathode
LED1 Any 3mm LED (batt low: recommend red or yellow)
LED2 Any 3mm LED (power: recommend green)
L1 SDR0603-3R3ML or compatible 3.3u >1A inductor
M1 Dual MOSFET N-ch Si4946EY
R1 1k 5% 0603
R2 39k 5% 0603
R3 1k 5% 0603
R4 1k 5% 0603
R5 0R or 4.7R or 10R 5% 0603 (gate leads of MOSFETs)
R6 0R or 4.7R or 10R 5% 0603 (gate leads of MOSFETs)
R7 1.5k 5% 0603
R8 1k 5% 0603
R9 330R 5% 0603 (optional: for low battery LED)
R10 1k 5% 0603
R11 330R 5% 0603 (optional: for power LED)
R12 0.1R 1/3W 1% or 5% 0805 (current shunt: recommend ERJ6BWFR100V)
R13 10k 5% 0603
U1 LTC4442 sync buck controller in MSOP8-EP
U2 LM393 or LM2903 or similar comparator with open collector/open drain (for push-pull version, omit R3) in SO8
U3 TL431 (+/-2% 2.495V voltage ref.) in SOT23
VR1 Bourns 3006P series 1k potentiometer
Q1 SOT-23 NPN transistor, BC847 etc...
Per thatoneguy's request, I've been working on a design to run a 1W LED from an ultra low voltage. Not a 5W one, but it should be possible to do 5W in future designs with a bigger inductor and beefier components. What makes it remarkable is it can output 200mA into a 3.5V LED at an input as low as 0.9V, and possibly lower in practice. It does require 2.2V to start up, which is its only limitation, but once started, from say 2xAA, it can suck every last joule from the cells.I am also interested in this.
Yeah, I've heard of the heat problem. Although an LED is still only 20% efficient (compared to a perfect light source); an incandescent is 1-5% efficient. So a 5W LED will dissipate 4W of that as heat. Nothing compared to say a 20W incandescent which will dissipate 15-19W, but still quite a lot. The driver I designed is a buck converter only, as buck boost are more difficult to design. If I were to design around a buck-boost topology, I'd probably use a dedicated LED controller IC.That last one is nice, would be better than the regulator I have for my snowblower LEDs (incadescent lights suck in freezing weather with vibration).
The only issue is heat, as in not enough of it. Same problem traffic signs have with keeping the snow melted off the lens. They now use a heater inside, I just need to wait for 5 minutes for the LED to be hot enough to melt any snow covering it.
Trying to come up with some nice headlights for an ATV, they are sold commercially, but the price tag is in the mid triple digits. The design above could be the ticket, I'll need to do some measuring.
candlepower forums has a ton of different buck/boost drivers for high wattage (3-5W+) LED drivers to run from a CR123, building them smaller is the hard part. (yes, I have a flashlight fetish)
This one would be for an ATV, which has a small 12V battery with magneto charging. "Clean" voltage is hard to get, so an input pi filter with inductor and caps would be needed, I'm just jotting down your circuits for ideas to make a "bulletproof" design. If made for winter, it overheats in summer, if designed for summer, snow continually needs to be removed.Yeah, I've heard of the heat problem. Although an LED is still only 20% efficient (compared to a perfect light source); an incandescent is 1-5% efficient. So a 5W LED will dissipate 4W of that as heat. Nothing compared to say a 20W incandescent which will dissipate 15-19W, but still quite a lot. The driver I designed is a buck converter only, as buck boost are more difficult to design. If I were to design around a buck-boost topology, I'd probably use a dedicated LED controller IC.
The module itself shouldn't overheat. In simulations, the MOSFET (Si4946EY) will hit about 30°C above ambient; which will be hot to the touch, but certainly no where near the maximum 175°C rating, even when taking into account the fact that it could operate at 50°C ambient temperatures. The rest of the board should stay cool. Also, for the input filter I'd advise a TVS in parallel with a zener too (both about 20-25V rated breakdown); the regulator will easily be damaged by input spikes - such an arrangement will remove almost every spike.This one would be for an ATV, which has a small 12V battery with magneto charging. "Clean" voltage is hard to get, so an input pi filter with inductor and caps would be needed, I'm just jotting down your circuits for ideas to make a "bulletproof" design. If made for winter, it overheats in summer, if designed for summer, snow continually needs to be removed.
Cool, I didn't know! If you want to keep up-to-date, here is the main thread: http://www.rcgroups.com/forums/showthread.php?t=1290963Don't go out of the way on this, I'm getting new ideas looking at your ideas is all. I'm interested as well with your OSD project, as I fly R/C too.
