Hello there,
I have hardware design in which I have used Buck-boost converter. Input voltage(from battery) is 6v and my MCU is running on 5v so I have using buck mode of the ic, but as soon as the voltage drops below 4.5v boost mode is used. Also current consumption required for me is around 850uA.
Currently I am using TPS63061DSC, but the problem is market unavailability. Long lead times are reported for this product. It'll be helpful if you can suggest any alternative for the same
