looking for cheap light way to get 200w 220v 2-3ph from 12vdc ro srart small 3ph genset, wired delta.single ph may do it with a coupling capacjfor to the adjacenr ph?
can lift dead mass, but not pull starter cord/hold genset down. without much pain. very weak. can just hold 1kg with arm extended for few sec.shortbus said:
You said in the other thread the gen was hard to pull start. If you are capable of carrying and moving around 8 to 10kg, why can't you pull the starter cord? I'm doubting it would take 1/2 of that amount of weight to pull start the motor.
