Hi all, new here. I'm having a little trouble figuring this out, hopefully someone can point me in the right direction before I give up.
What I have is a small light timer commonly used to control leds for aquarium lights or plant leds. Basically you can set it for 4 hours, 8 hours, or 12 hours.
What I want to do is two fold. First I'd like to change the timing sequence to lower it, but that might be impossible and may be built into the chip, but more about that later.
The other thing is I want it to spin a small dc computer fan. Seemed easy enough, until I hooked the fan up. It kind of chatters, but won't spin. There is very little voltage drop when I connect the fan, so it doesn't kill the output, but yet cant work. I can see it pulling current when I hook the fan up, and the fan by itself doesn't source a bunch of current, so not sure what is limiting it.
I thought it might need a flyback diode so I tryed a 1n4007, but no joy. Though its a modern fan so it might not need the diode anyway. The output comes off a A09T mosfet, which I believe is a 30v n channel mosfet. It also is switching the negative side on, as the positive is connected straight through to the source side. The microcontroller doesn't have an identifying mark, but is run off a 5v regulator, and has a what I think is a 16 mhz oscillator connected to it (H16.00).
Any thoughts? I've seen some posts on here with directions on how to make a circuit, but I thought I could make this work just for a different application.
