I will do just that!!! test it on breadboard and degug both hard and software...or will do straight PCB and will just debug the software...The PCB layout will be done from Eagle....correct? yes!The IC in post #75 is a 4017 Decade Counter (or also known as a Johnson Counter) here is a quick tutorial on the IC and its functions >> http://www.doctronics.co.uk/4017.htm
You would "simulate" the hardware on a solderless breadboard if you have one.... or redraw the whole thing in a different application that can also simulate it....
Usually I will draw up my schematic in eagle, then I will build the circuit on a breadboard which I include ICSP connections for my Pickit2/3 and then start on the software side, so I can test and debug hardware and software at the same time, so I can see if I may need to move an I/O to another pin, etc.
After all the software, and hardware debugging is done, then I will update the schematic with the changes (if I have not done so, usually I update it as I make changes to the circuit on the breadboard) then I will layout the PCB and make them from the final version of the schematic.
BTW, my chess engine is ready BUT I have not tested it yet...will do that on friday using two computers...one for the chess simulator and the other one for the chess engine! I will discuss it with you guyz for tips on how to implement the coms protocol...into the PIC
Thanks so much!
