The thread about hFE got me thinking about seemingly simple things that I don't understand.
Years ago I acquired a bushel of MDA2500 .
25amp 50piv rated.
Most every one tested @ 1000 volts with almost no reverse current. Less than 10uA.
It's been years, so I don't remember if that was per diode or thru bridge.
Since then I've used them on innumerable hobby projects. Some even mains powered.
Never a failure.
Anything critical I still use a proper piv rated component.
My question then is:
Are diodes made specifically 50piv?
Or are they produced in a batch and tested for labeling and sale?
What is the difference for a hobbyist, between A 400piv rated and a 50piv tested @ over 400volts?
Aging, heat, breakdown with high current? Failure to recover from a spike?
25amp 50piv rated.
Never a failure.
