Bridge Rectifier Frequency Limit
MGPERF
Joined Jun 8, 2021
77
Hello, I’m wondering about the frequency limit for a gbj1508-f bridge rectifier or bridge rectifiers in general. I cannot find it anywhere.
MrSalts
Joined Apr 2, 2020
2,767
Because it is designed for 50/60Hz like every other "standard" bridge rectifier so everything is specified in terms of 8.3mSec. If you want something fast, get four ultrafast recovery diodes snd make your own bridge.
Even if you measure the recovery on one gbj-1508-f, the next one might be different if you are looking for any frequency above 60Hz input.
schmitt trigger
Joined Jul 12, 2010
2,085
Just out of kicks, I once measured the Trr of common 1N40xx rectifiers.
As the previous post mentioned, Trr is literally all over the place.
Use UF40xx rectifiers for your own bridge, they are ubiquitous and low cost.
MGPERF
Joined Jun 8, 2021
77
Works in spice! Some major advantages to using a bridge rectifier for my application vs. just two diodes in a row.
