Bridge Rectifier Draws Excessive Current
12,131
The transformer works as expected without the bridge connected. The current draw anly happens when the bridge is connected son probably no short in transformer.
Reconnect the shield to the chassis with all secondaries still floating. If the shield is shorted internally to something on the primary side, this might indicate that.
BobaMosfet
Joined Jul 1, 2009
2,211
I pulled the datasheet for your diodes, and you're using the wrong diode. Reverse current max, for this diode is 50uA.
No really i checked it many many times. Transformer outs to anode cathode junctions. Outputs are anode anode junction
(to use as load ground) cathode cathode junction for the positive side. I dosen't make sense to me also that is why i suggested that i make a video. I will do that, i will be home in 45 minutes or so.
I'm not saying that you aren't seeing the problem, I'm saying that it isn't wired as you suggest-- it cannot be. It is physically impossible for there to be any significant current on the 9.4VAC secondary if the circuit is open as shown below:
We look forward to your video ;)
alisomay
Joined Jan 30, 2018
29
"Maximum reverse current = IR, the amount of current through the diode in reverse-bias operation, with the maximum rated inverse voltage applied (VDC). Sometimes referred to as leakage current. Ideally, this figure would be zero, as a perfect diode would block all current when reverse-biased. In reality, it is very small compared to the maximum forward current."
50uA seems small enough for me what would you suggest? By the way i think even 1n4007 is suitable for this operation. I just dont want to burn them that is why i test with larger Amp diodes. I will take the video in 15 mins.
alisomay
Joined Jan 30, 2018
29
Videos are ready! Sorry for my clumsiness trying to connect the bridge with crocodile connectors :) you should jump that part.
I was a bit excited it is my first video in the internet that i talk :)
The password for these two videos are : aac
In the first video i measure the mains power (i couldn't make contact with the probe leads properly but i think it is enough info) and the transformer secondaries.
Second video is about the bridge current problem diode testing etc.
ElectricSpidey
Joined Dec 2, 2017
3,335
You have constructed a direct short across one of the diodes.
Maybe even the other three, but my eyes are bad, so I can't see the polarity.
Ylli
Joined Nov 13, 2015
1,092
You have the bridge wired wrong. The way it is wired there is a diode directly in shunt to the secondary and will present a short during half the cycle. The power in should be at diagonal corners, and the output should be on the other diagonal corners. Look again at the schematic and your wiring.
alisomay
Joined Jan 30, 2018
29
I am now posting the close up of my wiring, it is exactly like the schematic. Maybe you can not see properly in the video, look at the junctions.
The green and black crocodiles are going to the transformer secondary.
The others are the outputs.
Do you still think it is wrong?
https://ibb.co/m2m3Ym
BobaMosfet
Joined Jul 1, 2009
2,211
Thank you for the video, it's great.
In the video your problem is that you are connecting the positive lead off the transformer on one side of a diode, and then you are connecting the negative side of the supply on the other side of the same diode. You must drop your potential across 2 diodes, not 1. See my drawing in my previous post, for correct way to do this.
alisomay
Joined Jan 30, 2018
29
Ah ok! Maybe i understood the whole thing wrong, i was always attentive about junctions but not in this point of view. I will try and give feedback right away.
BobaMosfet
Joined Jul 1, 2009
2,211
No problem. We all have done this. Sometimes, what the mind wants to see, and what's going on a two different things. I find myself obsessing over a schematic and a PCB when I'm about to get PCBs made for this same reason. Does the schematic work? Does the PCB actually match the schematic.
alisomay
Joined Jan 30, 2018
29
Yes! Yes! It such a fool of me you were right from the start. Yiili and Electricspidey also. I always looked to the junctions but never looked if that current is crossing from the same diode or not. Thank you for being such a helpfull and responsive comuinity. Now the circuit works as expected! Also this is not the first time i do rectification with a bridge ahh such a simple mistake!! angry to me :)))
Very happy :)
