MaxHeadRoom
- Joined Jul 18, 2013
- 30,815
Then it should still apply, no cap required.There is other electronics on the output, which are some led strips.
If 12vac source.
Since LTspice doesn't readily allow drawing diodes at a 45 degree angle, I usually draw a bridge as in post #33.In schematics I usually draw them like so:-
For a simple circuit that is not a big problem, but it is not a good approach to your documentation. A schematic is not a wiring diagram, despite the natural urge to make it serve as one, and pushing it to be one can seriously impair the understanding of a more complex design. A schematic is all about showing the design intent, signal flow, and *electronic* (not physical) relationships among the components with the greatest clarity. For example, I have at least seven different symbols for a 555 in my design library, all with different pin arrangements. None of the pin arrangements are the simple 1-through-8 pattern on the datasheet, but each one improved the understanding of what that part of the overall circuit was doing.I put the schematic together to represent how I was gonna solder it more than it being an actual schematic,
Sounds basically like what I showed in post #33.All four diodes have the bands pointing up, in two columns
It's exactly what you showed. But in this case, the words may be worth more than the picture when thinking of how to lay out a bridge.Sounds basically like what I showed in post #33.
If he only has LEDs and a relay or similar devices, he does not need the bridge capacitor.Is this what you're after? X2-1 is battery positive. When power drops off the relay falls out and the battery POSITIVE is directed to X3-1. X2-2 and X3-2 are NEGATIVE.
