Oven went WACKY!!! For the last year when SW#1 (ON/OFF) was pressed numerous times you would get nothing or any number of functions for other switches (F to C, Convection,etc.) eventually you would get ON with the appropriate LED lite and oven would work fine, all selection KNOBS would function properly. If you wanted to change anything once unit was working (CONVECTION, LIGHT, DEFROST, C/F) you would have to press that button numerous times and it may or may not work at all. Recently the switches stopped working completely OVEN would not turn on regardless of the number of times SW#1 was pressed. MY QUESTION: Can all five switches fail at the same time or is this a problem with the UI101 chip? I exchanged switch #4 and switch #1 and it made no difference. Continuity (on all 5 switches) showed between legs on top and bottom and DID NOT change if button was pressed? Was expecting continnuity on any two of the four contacts. Breville has NO customer service that can address these issues, their reply is "Trash it and buy a new one". Well MOMMA loves this little oven and that is what we did ($300) now the OLD one is mine to play with. I have found one source for USED control board ($60) but thought I would play a little before considering that option. Screen works fine so makes me believe it has something to do with switches or their circuits?
SW#1: POWER ON-OFF
SW#2; LIGHT ON-OFF
SW#3: CONVECTION ON-OFF
SW#4: DEFROST
SW#5: C/F
I had started tracing circuits but decided to post this and see what response(s) might be.
Thanks, Poppa D
31
SW#1: POWER ON-OFF
SW#2; LIGHT ON-OFF
SW#4: DEFROST
SW#5: C/F
Thanks, Poppa D
31
