Fabrication (F.Fab and B.Fab)
The fabrication layers are primarily used for documentation purposes to convey information to, for example, the PCB maker or the assembly house.
It's from the link in post #23Nice picture and exactly what I am using. Where did you get it from?
You do one of two things. You can either create a new footprint that macthes your receptacle. This would be simply a pad with an outline. This is the cleanest. Or you could banana_jack or whatever 1 pad footprint and do with it what I said in post #7.Any ideas on the J1-J62 connections? I am trying to set up my banana_jack_01 in my footprints. The actual receptacle is 0.078" in diameter going into the PCB hole and the tube is 0.200 in OD. I think the annular ring can be the same size. Do I have to do the same thing 62 times or can I copy this forward somehow in my footprint to symbol list?
I've never tried that before but I think you could just modify the footprint. Maybe you need to generate a new netlist in the schematic editor and load it in PCB New, I don't know. Are you sure it doesn't have pads? If you worked from the existing D-Sub footprint that comes with KiCAD it should have pads.1) I noticed that when I did the 62 pin footprint, I didn't change the mounting holes to pads and they should be pads because those tangs solder to it when it is mounted on the board. How can I add these in without damaging my layout now?
In PCB New, select the layer called Edge.Cuts. You can draw circles on that layer that will be mechanical holes. After this it may or may not be required to run the design rules check. That's the icon with the ladybug on it. I always do run it because that also recalculates the copper fill area that I invariably have. It doesn't hurt if you do.2) I have 6 mechanical mounting holes to add and I think I have this figured out but do I go into my schematic and add pad holes and make them NPTH mechanical holes? Do I then have to go through annotation, assignment and netlist again or how does that work?
Thread starter | Similar threads | Forum | Replies | Date |
R | USB-C Breakout, power but no data | General Electronics Chat | 9 | |
MCU Breakout Power Considerations | General Electronics Chat | 1 | ||
R | ESP32-WROOM with SD Breakout | Microcontrollers | 10 | |
Problem with LTC3855 sparkfun breakout board | Power Electronics | 12 | ||
B | 3w COB USB breakout newbie help | General Electronics Chat | 4 |
