Breaker and overload selection
jiugo.llamas
Joined Nov 23, 2007
10
Hi everyone, I would liketo know if there is any formula which I can use for the breaker and overload of a motor starter selection based on the motor´s hp´s or power, how can I select the right protections?????
Best regards
Hugo
gerty
Joined Aug 30, 2007
1,305
Chances are pretty good that your calculation will fall between the available fuse size (eg 4.5 amps) . You'll need to go to the higher size and probably a time delay or slo-blo fuse. A time delay will allow the higher startup current
to pass for a short time, but will blow if the current remains high..
