BP9831A data sheet
Status
Not open for further replies.
hp1729
Joined Nov 23, 2015
2,304
Can anybody find one in English? From what I can find it looks like VCC should be around 16 V. Can I get a confirmation from somebody?
debe
Joined Sep 21, 2010
1,419
If you look at the circuit I posted betwean pins 3&4 theres a capacitor 1.5uf & a resistor fed through droping resistors from the main supply.
hp1729
Joined Nov 23, 2015
2,304
It looks to me that the board is more designed for110 V. 240 V would put more stress on the internal Zener. Maybe 51K would be better than 150K for 240 v operation? But then it wouldn't work so well at 85 V :)
One board for 85 V to 240 V? Seems to have a shorter life at 240 V. :)
Wow, all the LEDs are in series? Current limiting is set to about 120 mA, 240 mA maximum.
Not a bad little chip. A bigger case with a bit of heat sink might be a good idea.
debe
Joined Sep 21, 2010
1,419
When it was working I managed to measure the voltage across the LEDs at 85V dc, & the current at 100ma. Just checked the Vcc voltage its 12V dc.
DickCappels
Joined Aug 21, 2008
10,661
After some discussion, this thread is in conflict with the User Agreement to which we are all a party. It is not closed.
Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
http://www.allaboutcircuits.com/user-agreement/
A not to those who participated in this discussion, I hope that the next time you find this sort of issue, you report it.
Status
