Does anyone know how to get the BOP firmware off of a SanDisk sport clip +? Mp-3 player with an Android phone? I'm just tying to get it back to factory, or put new firmware on it. Rockbox won't work.
I did figure out that I can't do it with this cheap ZTE phone. I'm in prison so I can't just run to the store and buy a galaxy. Lol.So did you ever figure it out?
How are you adding days and music? What do you mean by shortening the board?Yes it can't be done with ZTE because of OTG cabalities. I can add music with no problem. I can also add days to an expired mp3 by shortening the board. But the wait is around 30-60 days before I can power it up. I want to know how not to wait. If you know how?
How are you adding days and music? What o you mean by shortening the board?
I already made a info transfer wire. Which chip on the board, and which leg? Any resistance needed?Again you can't add music with ZTE. You need another phone like an LG or TCL then you need the right app to move the music to player and finally you need to make the cord. The adding days doesn't work ever single time but it's basically getting a wire to the positive side of battery and then to a chip on the board.
Send me your email address.I already made a info transfer wire. Which chip on the board, and which leg? Any resistance needed?
There's only one way I know that works, and it requires a computer.
- And which model player are you referring to? If it's the old Sansa clip with green display, an ordinary rockbox will run it. You'll delete the current firmware. It's relatively easy to do that one.
- But if it's the sport clip with color display, the firmware is a monster. Real hackers can't break it. As far as I can tell. No one has ever hacked the installed ATG firmware and got it working or off of it.
Thanks, if u ever figure it out, please shareWe've had success by going positive to some transistors that sit next to the memory chip. We understand that they control the actual buttons but don't understand why sometimes it works and other times it doesn't. So we are not sure just yet.
What is the right app to transfer music to the player?Again you can't add music with ZTE. You need another phone like an LG or TCL then you need the right app to move the music to player and finally you need to make the cord. The adding days doesn't work ever single time but it's basically getting a wire to the positive side of battery and then to a chip on the board.
Org disk explorer proWhat is the right app to transfer music to the player?
Otg, sorry autocorrectOrg disk explorer pro
Do you know why on some mp3s the app wont read them? They dont show up when i plug them in? Thanks for the appOtg, sorry autocorrect
Anyone know how to make the mp3 read the sd card?Otg, sorry autocorrect
By any chance did you ever figure it out?.my issue is that I downloaded some music via otg cable and ended with doubles of everything.so I scanned it on trulinks and now I'm not able to load more music using my phoneAnyone know how to make the mp3 read the sd card?
When you scan it to the computer it does something to it to where the phone wont read anymore what version is installed on mp3By any chance did you ever figure it out?.my issue is that I downloaded some music via otg cable and ended with doubles of everything.so I scanned it on trulinks and now I'm not able to load more music using my phone
1.09When you scan it to the computer it does something to it to where the phone wont read anymore what version is installed on mp3
Try doing a hard reset.turn the player on let it load all the way.then turn it off.wait like 10 seconds and this time you will hold down the power button and keep holding it down the player will turn on and you will keep holding it till the player turns off.when the player turns off finally let go of the power button the player will now turn on again and it will refresh the memory.once its fully finished and it goes to home screen plug it up to phone and try it now.let me know if it worked for you.1.09
Just tried it and it still didn't work.Try doing a hard reset.turn the player on let it load all the way.then turn it off.wait like 10 seconds and this time you will hold down the power button and keep holding it down the player will turn on and you will keep holding it till the player turns off.when the player turns off finally let go of the power button the player will now turn on again and it will refresh the memory.once its fully finished and it goes to home screen plug it up to phone and try it now.let me know if it worked for you.
Can we change firmware of neckband. | Microcontrollers | 2 | ||
B | DSO138 Firmware and Hardware upgrade | Test & Measurement | 6 | |
M | Trouble Receiving RS485 Data on EK-TM4C1294: MAX485 Communication Issue | Microcontrollers | 5 | |
B | STM32F446 booting | Microcontrollers | 1 | |
Siglent SDS2104X PLUS Firmware Upgrade | Test & Measurement | 1 |
by Don Wilcher
