bootstrap transistor.....
LvW
Joined Jun 13, 2013
2,035
According to Ohm`s law, the current through R3 is i=(vin-Avin)/R3.
Therefore, the coresponding conductance is
i/vin=(1-A)/R3 and the corresponding resistance is
vin/i=R3/(1-A) which is much larger than R3 because A<1 (but very close to unity).
This calculation assumes that the capacitor C is rather large (capacitive impedance negligible).
This "bootstrap" method is a kind of positive feedback which increass the input impedance drastically.
Zeeus
Joined Apr 17, 2019
616
Therefore, the coresponding input conductance is
Thanks...Trying to understand
"i/vin=(1-A)/R3 and the corresponding resistance is" is i = Vbe/R3?
so current that goes into the base is Vbe/re ?
How has increasing a.c value of R3 done any good? R3 will be in parallel with re at a.c.. no?
Also, Rin = Vin/Iin
Iin is Vbe/(re||R3) ?
thanks
Jony130
Joined Feb 17, 2009
5,599
First, notice that if the R3 resistor was connected between Vin and GND any change in Vin will cause corresponding change R3 resistor current i = vin/R3 hence rin = R3.
But in this circuit R3 resistor is connected between Vin and emitter. As you shoud know the AC voltage at the emitter follows the input voltage vin ≈ v_emitter. This means that the voltage across R3 is constant, hence for the AC signals, the R3 looks like a constant current source (a bigger resistor).
Examine this
When we have an ideal voltage amplifier with the voltage gain equal to A.
Now let us try to find the input resistance.
Rin = Vin/Iin
In = (Vin - Vout)/R = (Vin - A*Vin)/R = Vin * (1 - A)/R
Rin = Vin/Iin = R/(1 - A)
And if we use as our amplifier the emitter follower (voltage gain close to one)
We will have this situation
This is the bootstrap. The closer the voltage gain to 1 is the less current is drawn from the input source (increase in the input resistance)
And for your circuit Rin becomes :
Rin ≈ (β+1)*(re + RE)
Zeeus
Joined Apr 17, 2019
616
Examine this
Rin = Vin/Iin
Thanks Jony...Please post other links as usual
DOn't understand this : Rin ≈ (β+1)*(re + RE)
RE
is smaller now
Zeeus
Joined Apr 17, 2019
616
What part you don't understand?
If you want to be pedantic
\(R_{IN} \approx \frac{R_3}{1 - A_V}||(r_e+R_X)(\beta+1)\)
Where:
RX = R1||R2||RE
But normally R1 and R2 will be much larger than RE, hence Rx ≈ RE
\(A_V = \frac{R_X}{R_3||r_e + R_X} \approx \frac{R_X}{r_e+R_X}\)
R3/1-A is not in parallel with re???
Anyways, thanks...Guess i should skip the rigor since just starting electronics
sstandfast
Joined Feb 26, 2025
Hello, I understand that this is quite an old post, but can someone please tell me what document/book the screenshot in the original post came from? I would like to find a copy of it as the small snippet is written in a manner that I can easily digest and that makes me think the rest of the document will be as well. Any direction as to where to find it would be appreciated.
Thanks,
Shawn
