I am attempting to install the linux-GPID drivers onto my Raspberry Pi 4. There is actually a smidgen of info on how to do this in teh innerwebs. My issue comes with the bootstrap command (or app or program or code or whatever).
Following the directions from here I can get up to step 3.2 which involves using bootstrap. I cannot get this to work even after explicitly loading bootstrap.
Would anyone have an idea what to do? I am completely new to linux so I am just making guesses about what I am seeing.
Also... if you have any info on installing linux-gpio on a Pi 4 please raise your hand!
terminal output:
pi@raspberrypi:/usr/local $ sudo git clone https://github.com/twbs/bootstrap.git
Cloning into 'bootstrap'...
remote: Enumerating objects: 41, done.
remote: Counting objects: 100% (41/41), done.
remote: Compressing objects: 100% (36/36), done.
remote: Total 149225 (delta 16), reused 16 (delta 5), pack-reused 149184
Receiving objects: 100% (149225/149225), 150.35 MiB | 7.51 MiB/s, done.
Resolving deltas: 100% (98178/98178), done.
pi@raspberrypi:/usr/local $ sudo svn checkout svn://svn.code.sf.net/p/linux-gpib/code/trunk /usr/local/src/linux-gpib-code && cd /usr/local/src/linux-gpib-code/linux-gpib-kernel/ && sudo ./bootstrap && sudo ./configure && sudo make && sudo make install
Checked out revision 1869.
sudo: ./bootstrap: command not found
