I was wondering that as the difference in the voltage you desire vs. the voltage source increases, does it decrease the efficiency of the circuit or have any disadvantages if you were to put a buck-up (booster) module?
For example, a 3V battery needing to supply a 9V load versus a 6V battery supplying a 9V load.
The flow would be: Battery ---> Boost Module --> Load.
