You must know if you have a booster chip surely? I assume therefore that what you really want is a schematic based on non-single chip solutions eg using something like a 555/op-amps or transistors.I have quite a lot.
Need to know or see the schema u know
You could probably do it with a "Joule thief" style blocking oscillator, normally they operate from a 1.2 - 1.5V cell, the higher voltage means you need a slightly different feedback/bias arrangement. The feedback path needs a DC blocking capacitor, so then you'll need a base bias resistor to get the transistor started.Looking for diagram any one made.
Basically I need to boost a 3.7V Li-on to 30VDC. Max 100mA.
Any one ?
Also needs a 470 uh 2 amp or larger inductor. Everything else is pretty vanilla.
Just remember that any inductor make must not saturate. Saturation current is a pain to measure since you have to measure the inductance with a large direct current flowing through the inductor.I might need to wind an inductor. I have an inductance meter.
The basic self oscillating flyback converter that resembles the basic layout of the "Joule-thief" was a popular choice for the PSU in 80s home computers, Atari and Amiga are two such units I had a contract to repair PSU boards for.It sounds easy, but it is not as easy as it sounds.
100 ma is quite a bit for the little joule thief type circuits.
Is the load a constant 100 ma or is it more like 0 to 100 ma.
How about tolerances 10% ok?
Is switching ripple or noise an issue?
I have crude one based on a 555, but for the low voltage (3.7 volts) it would need a powered up cmos 555 to work.
Anyway, do you have any logic level FETs or fast low saturation NPNs good for 3 amps or so?
