Boost converter with tl494
mohammadhossein ajorloo
Joined Aug 27, 2016
17
Hi every body
I want to make 12 to 36 volt boost converter with tl494, but i can not run ic. I know that pin 12 is vcc, pin7 gnd, pin 6 and 7 for frequncy set, but I can not work with pin 1,2,15,16,4 and actually pin3 that is for feedback.
Alec_t
Joined Sep 17, 2013
15,154
I think the feedback resistors are giving the wrong feedback voltage. If R1=R2 then the voltage at pin 1 is 2.5V; so the feedback loop will try to adjust the voltage at pin 2 to 2.5V. That means your voltage divider from Vout needs to provide 2.5V. A 47k resistor and 1k pot (if I've read the values correctly) can't do that if you want a 36V output.
With R3=1k and R4=15k (?) the error amplifier gain is only about unity. Try swapping them over. Why didn't you use values similar to those in the datasheet?
Dodgydave
Joined Jun 22, 2012
11,395
looking at your circuit pins 1,2 need reversing, you need to remove R3/4 and connect pin 1 to the output resistor divider preset , pin 2 should be used as the reference source pin.
Like this circuit example....http://i.imgur.com/8ndwf.png
Note if the reference voltage on pin 2 is set to 2.5v, then your output voltage will be at 2.5v on pin 1 at shutdown, so use a 1k preset and 4.7k resistor.
Joined Aug 27, 2016
17
hi
i can finally solve my broblem with yours help. the problem was about my diod, it just can cross 2 amper bout i need 5A. and my feed back had a little broblem. i should thanks Dodgydave and Alec_t that help me a lot
