You must use NAND gates exclusively, yes? Your outputs get inverted, yes?But my problem is how to get complenment lines in order to form nand gates?
Please note [' = NOT] and I am not simplifying the expression in the following:I have a problem getting this following boolean equation into to using only nand gates. AB+DA+CA+DCB ... just can't figure it out with the basic rules of boolean algebra.
It doesn't, it requires:I see your point dave but the way you did it requires a not gate and nand gates...And my assignment was to use only nand gates.
which of the following boolean algebra expression is incorrect? | Homework Help | 3 | ||
Boolean Algebra question | FPGAs (Field Programmable Gate Array) | 14 | ||
Boolean Algebra | Off-Topic | 0 | ||
R | Boolean algebra simplification | Homework Help | 22 | |
I | Boolean algebra and NAND gate | Homework Help | 1 |
