BNo005 Bosch Sensor
nmsr1196
Joined Jan 10, 2013
I have the BNo055 sensor. The sensor I have have the I2C (SDA/SCA) pins. I viewed the Bosch calibration video on its PC calibration software. My question is how do you interface the BNo055 sensor to the PC?
nmsr1196
Joined Jan 10, 2013
So that I understand, This means that i can connect an breakout USB and tie it to the I2C pins to TX/RX for the PC?
ericgibbs
Joined Jan 29, 2010
21,562
hi,
If your breakout module has a RS232 input and a USB output to a PC , I use the same cable/module for that conversion.
Another option would be an Arduino with its USB cable and the Github software for the BNO 055.
Is this what you are asking.?
E
nmsr1196
Joined Jan 10, 2013
hi,
E
Yes Sir. I did not know about the Arduino option. Last question......would it work is I had a 4 wire breakout USB (keep the flat part and cut the cable and use the TX and RX)?
ericgibbs
Joined Jan 29, 2010
21,562
hi,
Of the 4 wires in the USB breakout cable 0V, D+ and D- would have to be connected.
On my Rs232 to USB converters, at the RS232 end, the Red wire is +5V, Black 0V, White TXD into the converter, Green RXD from the converter. [check that your wiring, to identify these connections/colours]
Don't connect the Red wire. +5V.
There is free download on the web called 'Termite' that enables two way communication using the RS232/USB converter.
E
