Blown components in Mitsubishi Carisma ECU
Status
Not open for further replies.
brainsofts
Joined Mar 25, 2015
2
Hi Guys,
I am trying to repair the ECU of my old car Mitsubishi Carsima 1.6/96. The check engine lamp is not working so I traced from the corresponding ECU pin and found that a resistor and transistor are blown. I think the transistor should be MOSFET but not sure.
I will replace them but the problem is the resistor is very burnt and difficult to identify the color rings and the transistor does not have any markings so I do not know what to use for replacement.
I have attached few pics of the board with focus over the dead components.
Can you help me please to recognize those components? Or maybe to use other alternatives which will do the job?
Thanks in advance. Nikolay
MCU88
Joined Mar 12, 2015
358
My best advice to you is to go to an local wrecking yard and purchase an used replacement on the cheap if you can and save yourself a splitting headache. ECU repairs are an specialized entity. There is an reason as to why your resistor and transistor has burnt out. You cannot just simply replace them, as it is likely that they will blow again. You must discover the reason as to why they burnt out to begin with. Kinda like when you blow an head gasket; why did it blow? No water? Faulty water pump? Blocked radiator? Thermostat not opening?
brainsofts
Joined Mar 25, 2015
2
Thanks for your advice.
I know the reason of blowing. It was my fault. I replaced all dashboard regular bulbs with led ones but one of them was short-circuited from the manifacturer. I replaced it but the damage was already done.
That is why I am almost sure that replacement of those elements should be enough. Everything else works OK with the ECU, only this bulb driver.
You are right about buying the replacement but I still want to try to fix this one.
Alec_t
Joined Sep 17, 2013
15,156
The pics don't help much :(. At least tell us the component numbers next to the dead components, e.g. Rxx, Qxx.
35,178
Sorry, wrong website, even though this is a repair.
The owners of All About Circuits have elected not to allow discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
This thread is against the AAC forum rules, Chapter 6, as seen here:
6. Restricted topics. The following topics are regularly raised, are considered “off-topic” at all times and will result in your thread being closed without question:
• Any kind of over-unity devices and systems
• Automotive modifications
• Devices designed to electrocute or shock another person
• LEDs to mains
• Phone jammers
• Rail guns and high-energy projectile devices
• Transformer-less power supplies
This can be found in our Terms of Service (ToS)
Here is a site that may provide you with some assistance: Electro Tech Online
Good luck
Status
