Hi guys im kinda new to electronics and i've been experimenting with some 2n2222 npn transistors, i've built this circuit and tried to measure measure currents and voltage drops across each component, what i think should happen is that if the base of Q1 is connected to the +5V supply , this should give( (5-0.7)/470) 9 to 10 mA i think is enough to get Q1 to saturation , now if i understand this correctly Q2's base should be connected to ground if Q1 is on , and so Q2 is off , then the LED shouldn't be lit , but it's actually on all the time so is there something i'm missing here? , also when i tried to disconnect the wire connecting the base of Q2 from the collector of Q1 and i would touch the end with my finger i noticed the LED is emitting again can someone explain this? , also i've over 10 of this transistor and i've tried replacing both of them with the same result , any help would be appreciated .
