I have to simulate a bipolar junction transistor in PSpice and investigate its behaviour. One of the things I have to investigate is the BJT with a base current bias. The circuit I am simulating in PSpice is attached. What I'm trying to do is plot the base current (Ic) vs the voltage across the collector and the emitter (Vce). The graph I get below is when I simulate using a DC sweep through the voltage source from 0V to 10V with a 1V increment. However, this is different to those I see in textbooks, which is a steep increasing curve, which then starts to flatten out past around 0.7V. Can someone please help me figure out what I'm doing wrong?
Thanks a lot!
Thanks a lot!
