BJT basic amplifier problem
Abhinavrajan
Joined Aug 7, 2016
83
Hi all.
Please have a look at the two attachments.
The first one is a biasing circuit.
In this circuit, I have to find the value of Rb1.
I have calculated that value which turns out to be 46.24k ohms.
But, it seems to be wrong.
I can't understand what mistake I am making.
If that answer is wrong, please help me with the approach to find the right answer.
The second ,attachment consists of a CE BJT amplifier.
I need to find the collector current and Midband gain of the amplifier.
Please tell me the correct method to approach to find the collector current and midband gain and help me solve it.
Thanks.
Alec_t
Joined Sep 17, 2013
15,152
Since this is 'Homework Help' you are expected to show your efforts so far. Show how you got the value 46.24k.
Use Ohm's Law to calculate the circuit voltages and currents.
Abhinavrajan
Joined Aug 7, 2016
83
Since, we know the value of Vb, Vcc and Rb2, I found the value of Rb1 using the voltage divider formula.
3.65=((12)(Rb1))/(105.8k+Rb1). I solved for Rb1 and found it to be 46.24k ohms.
hp1729
Joined Nov 23, 2015
2,304
Hi all.
Thanks.
When calculating the current through RB1 you need to subtract the base current from the current through RB2.
