BJT and MOSFET overheating in 555 timer wireless power circuit
nerdboy_Q
Joined Mar 11, 2019
I have been going online looking for some simple 555 timer circuits, just to verify my thought process, and they all relatively looks the same... but whenever I attempt to power my circuit, the bjt or the mosfet (I switch between the two to compare results) overheats. I'm not concerned with efficiciency currently, I'm just interested in proof that the concept works. My coil is ~10uH
I have used the exact circuit seen in the attached image, except the only difference is my bjt is a pn2222 & my power supply is 5V.Screen Shot 2019-03-10 at 11.52.19 PM.png
Sensacell
Joined Jun 19, 2012
3,787
This is an example of a "bait" schematic from the Internet.
While it's conceptually sort-or-correct, it's not a good design.
There is no path for energy stored in the inductor to flow when the transistor shuts off, except to over-voltage the transistor into destructive avalanche breakdown.
DickCappels
Joined Aug 21, 2008
10,661
Since you are apparently experimentin with the '555 you would probably be much metter off if you forget thus circuit and move in to the next.
pmd34
Joined Feb 22, 2014
529
Sensacell, pretty much has the right of it here, just for the sake of it though, your inductor is also on the small side so you would have to make sure you were operating at rather a high frequency to simply prevent a short circuit.
Alec_t
Joined Sep 17, 2013
15,156
Simulation shows that, for the R and C values shown in post #1, the pulse frequency is about 20kHz and the BJT would be dissipating several Watts on average, if it survived the excessive collector current and the high voltage spikes generated by the inductor's back-emf. A BD139 would be operating well beyond its rated current and power.
nerdboy_Q
Joined Mar 11, 2019
So I was originally testing the circuit out, and decided to think it through this morning. I figured a cap would be needed for the feedback from the inductor, but I thought (maybe they know something I don't)... clearly that was a mistake. So I did a few simulations this morning, and this looks like it may work.
My biggest question is, would this actually transmit the power? I haven't done any work with wireless circuits in a long time, and I'm trying to go back and learn through practice. Thanks for all your help!
Screen Shot 2019-03-11 at 7.52.49 AM.png (the pulse is simulating the 555 timer).
38,801
For a 10μh coil, the current will increase by 0.5A/μs with a 5V source when the transistor is ON, so you need to limit the ON-time of the transistor to limit the current to the desired maximum.
Thus if you want a 5A maximum, the 555 output should be high no more than 10μs with sufficient OFF time for the current to decay to zero (from the added free-wheel diode across the coil) before the next cycle.
