Should have done this yesterday
sleep took over = not a true intellectual
Someone please assist :
Due to R4 and R5, difference between emitter of Q3 and Q1 is about 5.6v..Emitter of Q3 be 6v and Q1 400mv (1mA which is same as 1mA on Q1's collector)
Since 1mA at Q2, it's base about 1.7V..Problem is that emitter of Q3 is about 10.5v..Like Q2 is cut off
Made a simpler circuit by omitting Q2 and everything checks out..gain was about 100 due to current source on Q1
Just want to add another amplifier to test understanding
Assist please..input impedance is problem?
Edit : 2 questions actually ..Similar to this i guess
https://forum.allaboutcircuits.com/threads/bjt-resistive-divider-biasing.160181/
for R4 and R5
1. R4 =7.5k R5 = 1.2k
2. R4 = 68k and R5 = 10k
3. R4 = 750k R5 = 110k
Using these 3 and simpler circuit, omitting Q2 with no current source on collector of Q1 and using 5.1k as collector resistor
emitter of follower = E
gain = G
1. E = 5.4v G = 9
2. E = 5.9V G = 11
3. E = 8.2V G = 9.2
Seems using 2, 68k and 10k was the best...How to know which to use ??
Thanks thanks
for R4 and R5
gain = G
1. E = 5.4v G = 9
2. E = 5.9V G = 11
3. E = 8.2V G = 9.2
Thanks thanks
