Bipolar Transistor (laboratory exercise)-PSPICE
EleniStefanidou
Joined Jan 14, 2016
9
Hi everyone!
My name is Eleni and I am a freshman in the department of automation engineering at TEI of Thessaloniki,Greece.This semester we have in our programm analog electronics which I love but I can't quite understant sometimes.
I have a specific circuit we have to solve and I am not sure how to continue...
These are all the specifications given:
VBB=VCC=5V
R1=4.7k ohm
RC=220 ohm
I found that R2 should be 0.7873k ohm so that the voltage at the base of the transistor is 0.7 V.
1st)Using that I found the current (-11.31 mA) and the voltage (-2.513 V) at the collector.
2nd)After that at a IC-VCE I have to put the Q and design the load line.
Can someone tell me if what I did is wrong and explain to me how to do the second part of my "homework"?
I know almost nothing about transistors and our professor nver explains to us what to do,so I would appreciate any help given.
Thank you so much!!!
Jony130
Joined Feb 17, 2009
5,599
But can post or quote the full question ? And your simulation circuit is wrong the battery are connected backwards.
Rebuild the circuit and repeat the simulation.
EleniStefanidou
Joined Jan 14, 2016
9
What made me post here was the fact the I couldn't find a way to "measure" the VCE requested (2.2).I was requested to put in a Ic-Vce chart the benchmark(?),Q,that I noted.After that I have to design the load line...
Thank you!
EleniStefanidou
Joined Jan 14, 2016
9
Oh,thank you so much!!!
It's my first time seeing something like this...During the lectures of Electronics our professors haven't yet said to us things like this...
EleniStefanidou
Joined Jan 14, 2016
9
I have to find the voltage between the collector and the emitter...but the fact that I put a GND_POWER makes the voltage 0...What does this mean?
EleniStefanidou
Joined Jan 14, 2016
9
Maybe I am confused over simple things but today was my first time seeing these.
Also,I am Greek so I am trying really hard to express myself as correctly as I can but ,oh lord is difficult.I'm really sorry for making it difficult for you to help me due to the way I express myself.No matter what I thank all of you for helping.
From the start of this project I couldn't understand how to make the chart when I couldn't even put a voltage marker to measure the VCE...
EleniStefanidou
Joined Jan 14, 2016
9
Well...this is my circuit all over the right side of the circuit the voltage is 0.I want to find the voltage between the collector and the emitter and I don't know exactly how I will do it.
38,764
As you vary the value of R2 from zero to it's maximum (at least 1kΩ), the transistor collector voltage should go from 5V to near zero volts.
An easier way is to use a current source directly into the base, instead of a voltage source with resistors, and vary the current source (pulse mode with slow rise time) from 0 up to say 1 ma and observe the collector voltage.
