When off base is 0v collector is 5vI would check the voltages on transistor Q1 for starters.
When OFF: base = 0 volts
collector = 5 volts
When ON: base = 1.2 volts
collector = 0.7 volts
Not using float switches. We have wires as probes to detect the presence of water. And, the sailboat is not always leaning over.I haven't read all of the post, but have you considered that when the boat is at say 45Deg, the floats may not work properly?
If you had a permanently running peristaltic pump, this wold self prime and pump any water as it arrives. (no electronics)
Yea they do look skinny. In the PCB editor they did not look skinny, I actually increased them from 10mil to 15mil and had to adjust them. I didn't check how wide 15mil was. This is the first time I had a PCB made from a vendor. I know better now for next time. In the breadboard that sghioto helped me with, the cathode is on pin 16 and that circuit worked as breadboarded. So not sure if i should switch it or not.In the schematic diagram it looks to me like the diode (D4) across the relay is backwards. That will prevent the relay from operating.
In addition, all of the PCB tracks are very skinny.
In addition to that comment - Q1, when activated by SW1 will be drawing all the raw current to ground (or common as the symbol shows). Q1 may now be blown out.the diode (D4) across the relay is backwards.
Yes, they are. And you may have a burned out trace, though that would be easy to find.all of the PCB tracks are very skinny.
That is exactly how it works on the breadboard setup.The idea is to switch K1 on when the high water sensor activates it. Once activated it remains held on via the low water sensor. When the low water sensor no longer senses water the relay shuts off and the pump stops running. I'm reading this and ignoring the presence of D4 all together.
Two wires and the pump works fine. It's a brushed pump.Finally, does your pump have three wires? Can you run the pump by hand on the bench by applying power to pins 1 & 2?
