bicycle power inverter
electronis whiz
Joined Jul 29, 2010
512
i made a power inverter for my bike so that i can listen to a radio setting in my basket if i want to. i have a generator that runs onn the back wheeel of my bike the wire is terminated in a quick conect i use thi to select between light or inverter. i made the inverter using a old transformer from a radio this steps 12Vac to 90-120 vac that conects to a socket i can plug a radio into. the transformer i used was ment to turn 120 v to 9-10 v ac but by reversing the windings it works the other way. the winding with more ohms will is made for the higher voltege.
(e.g. a coil with 20 ohms and a coil with 100 ohms the 100 ohm is primary the 20 ohm is secondary when used as step down. but reverse the coils 20 ohm primary 100 ohm secondary will step up.)
Wendy
Joined Mar 24, 2008
23,813
Please read the rules of the Completed Projects forum.
When posting a project please include the following information:
  1. A clear title that describes the project appended by the word 'Project:', for example "Project: 555 Audio Oscillator".
  2. A list of parts, equipment, software used.
  3. Details of any theory, references or information that may be applicable.
  4. Any schematics, source code, etc.
  5. A short description of what to do.
  6. In the interests of manageability and security, project files/code/schematics must be locally stored. Links may be used to provide supplementary information, however they must not provide the substance of the project.
This project has sat in limbo basically because it didn't meet the above requirements. If you want to resubmit this entry please rework the entry to meet the requirements, then drop one of the moderators a PM pointing to it. If it is acceptable a moderator can move it back to the Completed Projects forum and clean up notices and suggestions (making them invisible).
There is no substitute for plans, schematics, photos, and basic prints. This sounds like an interesting project, but there simply isn't enough information.
