better way to buffer uart
bug13
Joined Feb 13, 2012
2,002
Hi guys
I find myself quite often need to buffer a packet of data from uart, then the main application will need to process them. Here is how I usually do it.
Code:
typedef struct{
    uint8_t data[MAX_SIZE];
    uint8_t pointer;                              // pointing to next empty location in a buffer
    uint8_t isReady : 1;                       // set if the buffer is ready to be processed
    uint8_t isBeingWriten : 1;              // set if the buffer is being written to, usually in a interrupt.
    // maybe other flags
}my_struct_t;
volatile my_struct_t my_struct[BUFFER_LEVEL];
// return the index of an empty buffer, return 0xFF if no empty bubfer
uint8_t findEmptyBufferIndex(void){
    // disable uart interrupt
    // do stuff
    // enable uart interrupt
// return the index of a buffer that is ready to be processed by the main application., return 0xFF if there is no buffer to be processed
uint8_t findReadyBufferIndex(void){
    // do stuff
Is there better way to do this?
WBahn
Joined Mar 31, 2012
33,089
The common way of dealing with needs like this is to push the received packets into a FIFO and then pull them from the FIFO. That isolates the data producer from the data consumer as long as the FIFO is large enough either to never fill up (if you want to be able to always service incoming data that can't be throttled) or ever go empty (if you want to be able to consume data at a constant rate). In the case of most UART traffic, it doesn't take much of a FIFO to pull this off, perhaps just two slots even, as long as the system pulling data is responsive.
35,070
You could use a circular buffer but I use a simple array.
The basic premise is that :
1) Information comes in as a packet and the maximum length of the packet is predetermined.
2) Packets have [start] and [end] characters.
3) The processor can handle packets faster than the rate at which they arrive.
The packet is processed only after the [end] character has been received.
I never disable interrupts.
