Hi All,
I wondered if you could provide some advice with regards to a filter I am designing for the output of an analogue sensor that outputs a voltage between 0V and 5V I then need to step this down to 3V3, but I am only interested in frequencies up to and including 72kHz anything above this I want to reject, because this signal is also used for control feedback I also need to reduce the phase ( less than or equal to 10 degrees). At the moment attached is what I have done just a potential divider with a capacitor, if anyone could suggest anything that would perform any better.
Kind Regards
Art
Kind Regards
Art
