BENQ FP71G SMPS fault
xblitz
Joined May 2, 2021
17
Hello
I try to repair the SMPS of my benq fp71g monitor - I know is a hold monitor - but it's
still suitable for me and I repair it for hobby too.
Two years ago I replace many electrolitic capacitors. Now, no other capacitor seem swollen.
https://elektrotanya.com/benq_q7t4-fp71g_sm.pdf/download.html
Schematic is identical to this https://manualzz.com/doc/24617979/benq-lcd-q7c4--fp71v---spare-parts-list except for inverter part.
The fault: I try to power on and nothing happen, no green or amber light no display osd...
When I open the monitor I found the main fuse blow up and the power mosfet (2sk3530) in short circuit between drain and source and a resistance of 140 ohm between G and D\S terminal (D and S are in short circuit...)
I replace 2sk3530 and fuse, check R615 (good) and turn on the power (I use a light bulb in series to AC plug).
Now the SMPS try to start, I see light bulb flashing, backlight stay on for 0.5s or less: I see the OSD but after tihs the monitor turn off, no amber light. If I retry to power on it retry to start again, light bulb flashing, backlight stay on for 0.5 - 1 s.....
I try to unsolder T601 pin 10 (V-inverter) but nothing change.
5V are present and also 3.3V
I can notice a fluctuation of 5V when the light bulb flashing with and without the pin 10 soldered. I should try to disconnect inverter and "replace it" with a dummy load? what kind of dummy load? Resistor? light bulb automotive?
Could be PC123 or TL431 damaged? or in the worst case T061?
Regards
xblitz
Joined May 2, 2021
17
Today I try some stuffs.
Fist of all: I test optocoupler pc123 and it's ok. Next I try measure the ripple between terminals of main capacitance. I found a ripple about 160V with and without light bulb in series of AC power. If I try to power on without the light bulb in seriea AC power I can hear T601 "twitting" and I can see ringing artifacts.
My question is: these could be a symtomps of a damage on primary side of T601 or it could be simply C605 in fault?
D601 seems ok
xblitz
Joined May 2, 2021
17
Day three. GOOD NEWS!
when I have the power PCB upside down I see a spark from capacitor of RC snubber. As a result I replace the related capacitor and the monitor power up correctly. Unfortunately I don't have the capacitor (I must buy it) so I use a capacitor of identical PCB. Unfortunately T601 still twitting but it could be normal?
Anyway, these are the capacitors. They looks like tantalium cap but they don't have any polarization indication. I suppose they are ceramic type cap.
It seems a good idea replace all 4 caps. On the body I can read:
U2 15J 3kV and 5D 3KV
Can someone tell me the carachteristics of these cap? I suppose 3kV means 3 kVolt...
