Beauty
killivolt
Joined Jan 10, 2010
836
https://home.cern/news/news/accelerators/ls2-report-new-lhc-collimators
Upgrades of the LHC collimation system, which began during LS1, have continued during LS2. Sixteen new collimators have been installed in the accelerator over the last three years in preparation not only for the accelerator’s next period of operation (Run 3) but above all for the future High-Luminosity LHC (HL-LHC).
The HL-LHC, which is due to be commissioned at the end of 2027, will improve on the current LHC’s performance thanks to a tenfold increase in its integrated luminosity, i.e. the number of collisions per surface unit, thereby increasing the number of collisions inside the experiments. To achieve this, the HL-LHC’s beams of particles will be more intense, which is not without its problems.
kv
killivolt
Joined Jan 10, 2010
836
Super cool stuff. I'm familiar with industrial type beam collimation.
https://en.wikipedia.org/wiki/Collimator
I haven’t had time to play around or toy with this for awhile. But it has to do with a friend of mine, his ideas formed from publications, disseminated by the Press, either Scientific Journals or other lets just say, Media, and I don’t care.
His idea that was formed was Antimatter, he said Quote: CERN is creating Antimatter and if handled improperly could potentially destroy the earth.
I said nothing, I can explain it to him, but can’t understand it for him. By default it is he who must research to know their is a layer to maintain, the layer is rate of decay, so quick as to steal any knowledge gained through the process of creation. Here and gone again. Pop.
Hello good bye, see ya in the future fellas.
But is there any truth in what he’s saying, why are they reporting such madness? Just for the effect? Truth or Lies?
What do you think and why?
kv
ZCochran98
Joined Jul 24, 2018
356
I mean, it could, but you'd need about \(2.77\times10^{15}\) kg of it to do so (to overcome the gravitational binding energy of the earth). That, for perspective, is about 0.0000000463% the earth's mass (or about 12.6 Halley's comets). For more tangible perspective, this would be a mass roughly the size (and composition) of a small asteroid 6.7 km in radius (13.4 km in diameter, or a little wider than Washington, DC).
killivolt
Joined Jan 10, 2010
836
Attempt a simple explanation please. Explain how this is so destructive. Is it explosive? Or the opposite? Seemingly ripping apart the earth chunk by chunk maybe similar to objects of similar size although one smaller than the other attracted spinning oscillations faster and faster, conjoining as twin bodies that find equality eventually to a coherent oneness in space Or is it more reactant now a force becomes relevant to heat both creating a causation event that does a similar thing. Wherein, molecules or particles begin to combine and a heat overwhelmingly results in a sudden explosion over time either instant or of a time duration, a critical mass explotion.
Is it the formation of a Blackhole, predecessor to an event? Or is a Blackhole something entirely different.
kv
Your friend is talking about the effects of Annihilation
http://www.astronomy.ohio-state.edu/~ryden/ast294z/solution_5.pdf
Burning one gallon of gasoline releases 1.3 × 10^8 joules (130 million joules) of energy
Here’s the question: If you were capable of converting mass to energy with 100% efficiency, how much mass M would you need to produce an energy E = 1.3 × 10^8 joules?
This mass can also be written as 1.44 micrograms; it’s roughly equivalent to the mass of a single grain of sand 0.1 millimeter across.
https://home.cern/news/news/physics/cern-approves-two-new-experiments-transport-antimatter
killivolt
Joined Jan 10, 2010
836
I’ll study this today, food for thought, haven’t had much time as of late to do so, far to busy these days.
kv
Edit: If your agree leave a like, if not add to or take away, however, cite your research or claim to the discussion or conjecture is welcome.
killivolt
Joined Jan 10, 2010
836
1. Therefor, based on the above model, the grains of sand combined to equal Washington D.C. in post #205 Energy to Mass equivalent, describes the Energy proposed to destroy the earth, does it or could it as a reactive agent produce a particle to particle force as to turn the earth into a neutron star, a causation expanded particle nuclei physical thermonuclear reaction or combined reactions.
Or
2. Slowly ripped apart by simpler forces, 2 similar objects in space slowly intertwining ripping each other apart, the eventual results one object returning to equilibrium Merging. This is a mass to mass equivalent. I would assume so is the above, but for different reasons all together.
kv
ZCochran98
Joined Jul 24, 2018
356
Indeed, I was referring to the effect of annihilation. Matter-antimatter collisions convert both masses into energy (so, really, I'd need half as much mass as I initially stated if you consider the amount of mass that would instantly be annihilated - the total mass would come from half matter, half antimatter - this correction halves the volume, meaning the radius of the mass should really be 5.3 km, or 10.6 km wide - about 2km wider than Everest is tall). The energy calculation is as "simple" as \(E=mc^2\) and solving for \(m\), knowing \(E\).
This amount of energy would shred the Earth apart, though how, I'm not entirely certain. It wouldn't compress the Earth, forming a neutron star, but it would instead create enough energy that would manifest itself as mostly heat, with a decent chance of igniting thermonuclear reactions. Alternatively, the Earth could just straight up explode, sending bits of itself flying in every direction due to that much energy being absorbed by and breaking down the atomic bonds of the materials that make up the planet. In the long run, it'd be easier to fling a small (60ish-mile-wide) asteroid at the Earth and call it a day, if you wanted to destroy the Earth.
Now, there are theories that you can create a black hole from energy (it's called a "Kugelblitz"), but it requires an obscene amount of energy condensed in an area smaller than an atom (based on the Schwarzchild radius, it would have to be about 2 nano-Angstrom wide [0.23 attometers], or \(2.3\times10^{-9}\) times the width of a Hydrogen atom for one with the energy equivalency of the energy produced by the sun in 1/10 of a second - or about \(3.8\times10^{25}\) Joules). So, indeed, this amount of energy produced to overcome the gravitational binding energy of Earth could create a black hole, too, but it'd need to be compressed quite a bit (inside the radius of 0.462 pm [\(4.62\times10^{-13}\) m]). This would be a tiny black hole, and the initial laser blast (as it would have to be, as the corresponding mass of antimatter to create a Kugelblitz would already have become a black hole in order to keep the annihilation energy release in the appropriate radius) to create such an object would be billions of times more powerful than anything we have today, even if pulsed for the smallest fraction of a second.
To answer an earlier question, in the long run, I think media and "science media" (not journals, but things like "Scientific American" and "Popular Science") like to report "CERN has the capability to destroy the world" or "CERN can create miniature black holes" because it gets clicks/reads, not because they're actually true statements. The media, even "science media," seem to rarely ever report scientific phenomenon accurately. Just look at the neutrinos discovered in the arctic a couple years ago that media reported as "going backwards in time" (they weren't; they were just undergoing a time-symmetry transform, which can be as simple as physically going backwards out of something rather than entering it. In this specific case, I don't recall the exact time-symmetry transform they were undergoing), or when they reported on structures like "time crystals," which aren't nearly as cool as they sound (a physical, time-dependent structure that is periodic and cyclical with a regular structure in time). So yeah: I think they report things like this just for the effect. Some may be intentionally lying, but I think it's mostly to drive clicks/reads. Even the reports of room-temperature superconductors are somewhat misleading, as the headlines never mention the pressures required to achieve them (though those pressures usually are at least mentioned in the articles).
For the record, as it can be hard to visualize the size of the theoretical "antimatter asteroid" I mentioned, here's a size comparison of some asteroids to a sizeable city (NYC, I think). The Chicxulub Impactor is roughly the size of the "antimatter asteroid." This screenshot is originally from a video by "MetaBallStudios"
cmartinez
Joined Jan 17, 2007
8,869
Many years ago, I read an article about the story of the general solution to the cubic equation ... I still wonder why there's not an entire book dedicated to it ... or perhaps there is? ... beautiful indeed :)
https://www.math.columbia.edu/~woit/wordpress/?p=13123
While some of these 1276 papers could equally well be simply characterized as “Mathematics”, it’s hard to describe exactly what makes a lot of the rest “Physical Mathematics” rather than “Physics”. Part of the answer is that these are not physics papers because they don’t answer a question about physics. A striking aspect of the survey is that while a lot of it is about QFT, the only mention at all of the QFT that governs fundamental physics (the standard model) is in a mention of one paper relevant to some supersymmetric extensions of the SM. The only other possible connection to fundamental physics I noticed was about the landscape/swampland, something only a vanishingly small number of people take seriously.
Also striking is the description of the relation of this field to string theory: while much of it was motivated by attempts to understand what string/M-theory really is, section 3.1 asks “What Is The Definition Of String Theory And M-Theory?” and answers with a doubly-boxed
We don’t know.
with commentary:
This is a fundamental question on which relatively little work is currently being done, presumably because nobody has any good new ideas.
In the background of this entire subject is the 1995 conjecture that there is a unique M-theory which explains various dualities as well as providing a unified fundamental theory. After nearly 30 years of fruitless looking for this, the evidence is now that there is no such thing, and maybe the way forward is to abandon the M-theory conjecture and focus on other ways of understanding the patterns that have been found.
cmartinez
Joined Jan 17, 2007
8,869
Where was the first time you heard of a tesseract? For me, it was in Madeline L’Engle’s “A Wrinkle in Time”. When I first read it, I was 10. The story and Heinlien’s short story “Life Line” taught me how to visualize four dimensions mentally.
Yeah, I read that novel too, when I was a kid. As for visualizations, I remember an old article in Scientific American that talked about the subject.
dcbingaman
Joined Jun 30, 2021
1,065
The 'laws' of physics start off simple enough, or so you would think. Like the law of gravitational forces. What could be simpler than it being proportional to the product of the masses involved and inversely proportional to the square of the distance between them? Combine that with F=ma and consider the following:
Take those 'simple' laws and try to apply them to a 'simple' system of say 4 spheres each with a specified mass, specified initial position in 3D space and a specified initial velocity as a 3D vector and calculate the positions over time for just a short while and the calculations become next to impossible without a very powerful computer. Move to 10 such objects and the long term system predictions become nearly impossible to solve.
Again, the laws of chemistry seem simple enough and derive of course from quantum physics as well but try to determine the behavior of a 'simple' prokaryotic cell using just the laws of chemistry and no computing machine on earth can predict the future state of such a living system.
There are plenty more examples. Then you have the major problem in physics in my mind:
Even if we do 'know' all the laws of particle physics from experimentation and application of the scientific method and the mathematical relationships that determine their interactions, the question of why the rules are what they are will remain a mystery that no amount of discovery can determine.
MrAl
Joined Jun 17, 2014
13,828
You probably know all this already but i couldnt help but mention some of this simply because it's such an amazing part of life and existence.
I think this is something like what we call "emergence". That's quite an amazing concept. A lot of little things create huge systems that can vary wildly, even though in theory they are predictable, or at least if we could calculate everything in a reasonable amount of time, which for many we can not at least not yet. Hopefully quantum computing will help with this if we ever really get that far.
Another example is that computer simulation they used to call simply, "Life". You would start out with a set of 'living cells' that have to obey some simpler rules depending a lot on how close they are to neighbors. They either life or die, and if they live, they join with other cells and it keeps going and going but the shapes and number of cells changes wildly. To calculate what would happen in some closed form function would have to be impossible.
It's amazing how all this works when you think about it. Some systems die out, or live for a long time then die out, yet some go on for what looks like forever. There are so many little things that can vary so it's hard to predict what will happen with different initial states. We call it a mystery just because we cant calculate it yet or come up with a simple set of laws that explains the entire behavior.
It's also amazing that if it were not for that, we might not be here, or we might all look exactly the same and perform the same routines day after day without variation, interacting more like robots that have a simple programming.
dcbingaman
Joined Jun 30, 2021
1,065
I write software applications, sometimes just for the enjoyment of it. One I made that I enjoy watching is John Conway's 'Game of Life' simulation that does create some rather interesting patterns (I think it is the one you are referring to). In this one the 'world' has no boundaries and you can zoom in and out and pan around. Very simple rules that result in rather fascinating patterns. Now there is about as many variations of that as there are creative people to think up the rules.
MrAl
Joined Jun 17, 2014
13,828
Yes that is probably it. My first exposure to this was back in the 1980's and i dont remember much about it now other than the hugely different outcomes with different initial setups.
dcbingaman
Joined Jun 30, 2021
1,065
I learned it manually just using a checker board or chess board. To play it is this simple:
1. Start with any pattern you want of black checkers on the board.
2. Look at each block on the checker board one at a time. If the block is empty and there is exactly three black checkers surrounding it (that is in the 8 blocks adjacent to it). Place a red checker on that spot.
3. Look at each black checker on the checker board, if there is less than 2 black checkers surrounding it or more than 3 black checkers surrounding it, remove the checker from the board.
4. Replace all of the red checkers with black checkers.
5. Return to step 2 and repeat as many times as you desire.
The 'edges' of the board though does cause problems as what to to with those checkers. I think in Conway's game the board has an infinite number of rows and columns.
Obviously you cannot get to many complex patterns on an 8x8 board but it is fun for kids as it teaches patience and concentration. You can also experiment around with changing the 'rules' and see what happens.
cmartinez Off-Topic 2
marshallf3 Analog & Mixed-Signal Design 6
