BCD Counter 74LS90 Doesn't start at 0000
skrilly
Joined Dec 10, 2023
Hello! I have a problem with my circuit that I translated from Multisim to pcb, in Multisim my counter works perfectly (BCD starts at 0000), my main problem is in the PCB, my BCD counter starting at an undefined state, sometimes 1111, sometimes 0110, my switch is connected directly to a 5V voltage regulator directly to the power supply (the GROUNDIN and VOLTAGEIN ports), what could be causing this BCD to not start at 0?
I was thinking of putting the toggle switch on a different location and maybe it will fix this problem....? I'm not so sure
1702203082171.png​
Ian0
Joined Aug 7, 2020
13,317
There is no guarantee what state it will start up in.
If you want it to start up at 0, then you must implement a power-on reset circuit.
skrilly
Joined Dec 10, 2023
Which pin in the 74LS90 can I use for that? There are 2 reset pins in the 74LS90 if I'm correct
Ian0
Joined Aug 7, 2020
13,317
Either of the R0 pins
[Correction] BOTH the R0 pins.
A TTL IC with positive-going resets? Whatever next?
