Yes, you need a difference in voltage to 'move' the charge from the supply to the battery. Maybe the charger is labeled so that you only use it on that battery.
You could hook it up to the battery and then measure the voltage going to it, it should be higher than the battery. Although, Li-ion chargers are generally pulsed on a logarithmic scale but its worth a shot.
