Battery pack with 18650 cells
Kristian83
Joined Nov 11, 2017
1
Hi
I'm making a batterypack with 18650 cells. The voltage i need is 11,1 v (12v).
I was hoping that someone with more knolledge than me could take a look att my configuration and tell me if its right.
I have eight 18650 cells 2000 mAh. What capacity will this configuration give me?
Thank you
/Kristian, swe
ian field
Joined Oct 27, 2012
6,536
Hi
Thank you
/Kristian, swe
I'd invest in a good fire extinguisher if I were you.....................
dendad
Joined Feb 20, 2016
4,642
I would say to not have uneven groupings of batteries. If you have 2 in parallel, do not then change to 4!
All groups need to be the same or Ian Field's comment it likely to be correct.
ian field
Joined Oct 27, 2012
6,536
Probably not that dangerous if the TS adds a charge balancer board, but 2P combinations stacked in series with 4P stages; will discharge sooner and the current flow pushed by the other cells will try to reverse charge them. That can't be good!
