Battery Over Charge Protection Circuit
Ijaz Ul Haq Pukhtoon
Joined Dec 14, 2016
1
I want to build a overcharge protection circuit for my 12v battery charger.
When the threshold voltage is reached, charging should be stopped.
Any help appreciated.
Please tell me as simple as possible
hp1729
Joined Nov 23, 2015
2,304
Design 708 overvoltage detector.PNG View attachment 116869
What are you using now? Can you modify that?
A voltage comparator monitoring the output of the battery, set for 13.8 V (Lead Acid type battery?). The output clears a latch that turns off power to the charger. Or maybe just cuts it down to a trickle charge.
How is your electronics? Can you build something if given a schematic?
Just a starting point ...
(image updated for design error)
Still not actually built yet, just a starting proposal.
18,126
Actually one of the simplest and most widely used solutions is a LM317 circuit, adjusted to the targeted trickle voltage. Charging never really completely ceases, but it gets very small as the target is reached.
