Battery Life Calculator
liteace
Joined Mar 7, 2012
242
Do I add the 18650's together when entering their mAh, ive got 3 x 2200 so does that enter as 6600 or does it not work like that ?
Ya’akov
Joined Jan 27, 2019
10,368
Thanks, If the batteries are connected in series whats the calculation for the mAh?
The total will be the same as the single cell. Think of it this way: if you wire the batteries in parallel you increase the current capacity; in series you increase the voltage.
