Battery (Li-Pol) to DC 12v circuit
kmwise97
Joined Jan 15, 2017
First of all I am new to this forum and looking for some insight for a project.
I have a little blue tooth receiver coming in the mail that I'll use in my car and at home but as I'm waiting for it I want to get the issue of powering it out of the way. I have a switched DC jack and a Li-Pol battery and would like to ask if there's a circuit I could build to disconnect and charge the battery while the module is powered by DC?
kmwise97
Joined Jan 15, 2017
The bluetooth receiver runs on 3.7 but I have a buck regulator to step the 12v DC down to 3.7 so it can run on DC as well.
kmwise97
Joined Jan 15, 2017
So it is a charger circuit for a single LiPo cell that you want?
What do you want to use as the power for the charger?
Pretty much, a circuit that would disconnect the battery when using the DC input and I guess I would need a separate port for charging? Or could the DC charge and power the module at the same time?
AlbertHall
Joined Jun 4, 2014
12,663
The DC input would be 3.7V to power the bluetooth and you would have to boost that up before you could use it to charge the battery. A LiPo charger could run from the 12V.
kmwise97
Joined Jan 15, 2017
Could I have a SPDT switch to toggle between charging and powering the Bluetooth? I could just the the power before the buck regulator to get 12v so I wouldn't have to step it up.
