battery charger capable of testing a battery if it is suitable for charging or not
ProfGreddy Emmanuel
Joined Feb 14, 2017
hi guys, am facing a problem on how to design and implement my final year project on design and implementation of a 12v car battery charger, of which it will be capable of testing the battery before it starts to charge. the charger also must be capable of displaying test result (if suitable or not) on an LCD. the charger must be user interractive in a manner that the user will be able to select the test mode or charging mode through keypads.
MrAl
Joined Jun 17, 2014
13,680
One test would be to charge with a light current and see that the voltage is either increasing toward normal or not, and if it keeps going after that. Then a higher current momentary charge to see if the voltage goes up too high in a short time.
There are probably other tests too.
shortbus
Joined Sep 30, 2009
10,050
Many of the new chargers use some type of comparator circuit. when first connected to the battery, if there isn't a high enough voltage on the battery it won't put out a charge current.
