For fun!Audio amps are so cheap now it makes me wonder why anybody would build one.
Sure, but one may want to design some frequency shaping into the amp, including adjustable EQ. By the way, your link is a DC converter.A "broadband amp can be used as a bass amp since the bass range is just a subset of the full audio range.
http://www.ebay.com/itm/DC-Converte...183?pt=LH_DefaultDomain_0&hash=item27dbe3ae77
You can add the effects externally.
Yep, this place does that some times: I post a link and it grabs the previous one I posted in another thread. Have no idea why.By the way, your link is a DC converter.
Thank you , I'll check it out !You're interested in an algorithm for calculating a 20W audio amplifier? Or you just looking amplifier circuit diagram to build it?
If you want to build an audio amplifier then I recommend you analyze the project attached. Contains all necessary information. It is a simple design, compact and Hi-Fi.
