Hi
I have started learning 8051 microcontroller using this book. You can see the list of the chapters in the attachment. In first five or six chapters the book uses assembly language and afterwards it uses C language. I have some basic knowledge of C++ programming.
Is there any software available (I'm sure there would be one) which I can use to learn the basic assembly language programming, or programming in general, of 8051? For example, when I was learning basic C++ I used CodeBlocks compiler. The compiler, simulator or whatever you want to recommend me should use graphical user interface (not some DOS kind of stuff). Thank you for your help.
Regards
PG
Regards
PG
