Basic understanding of usb3 power (Android)
Joe Stavitsky
Joined Apr 5, 2020
141
I bought a used Pixel 3 android handset. I had on hand a usb3 "pass through" indicator that displays supplied watts as an integer value. It ranges between 3W and 7W with a "dumb" wall charger.
Is this "normal"? If not, should I blame the phone or the indicator? Do I need to setup a breadboard with a DMM for reliable results?
Thanks so much
Joe
Reloadron
Joined Jan 15, 2015
7,977
The phone determines the rate of charge. The charger need only supply the correct charge voltage the phone controls everything else. I have no clue what you are using as a metering device for your USB line? Assuming a 5 volt supply I get 3 watts / 5 volts = 0.6 amps and 7 watts / 5 volts = 1.4 amps, neither is unusual. Again, no clue how accurate your measurements are or how efficient your phone charging is.
Ron
Joe Stavitsky
Joined Apr 5, 2020
141
Ron
I have no massive reason to trust the meter, I paid something like $10 for 4. I guess the most I can expect out of it is a notification of something going drastically wrong.
Thanks again
Joe
