I'm not quite sure about the specification of Gate-to-Source Forward Leakage (I_gss) given in many datasheets of MOS-FETs. I researched its definition and it seems to be the leakage current (for specific gate-source voltage), that flows from gate to source, while drain and source are shorted to ground.
E.g. the BSS138-G specifies 100nA. Does that also mean in the schematic attached there are 100nA flowing in/out of the gate of the MOS-FET? Since the current flowing in/out of the gate results in an error, given that the load current should equal 10mA. I would be interested to estimate that error. I know this should result in a tiny error in this case but for other designs it might be more significant.
Thanks for your help I did some research but I could not find the answer.
Best Regards John
Best Regards John
