Hi all,
I'm stuck about resistor value under LM 285, and also current direction, in short.
1st question:
current directions right or false?
2nd question:
Transformer : 10 VA 9V 1.1 A
After bridge rectifier: (9*1.414)-1.4= 11.32 V
Positive end of 1000µF - 50 V capacitors to ground, so -11.32 V to LM385 anode.
See Sketch 2nd Question below.
I guess need adding a resistor to get voltage drop of - 10 V ?
So 11.32/680 = 16.17 mA I2 = -16.17 mA
I L385 = 16-16.17 = 0.17 mA
I L385 = 602 µA -(-16.17 mA) = 16.17 mA I Forward Max: 10 mA.
As mentionned above, really stuck how to find this resistor value, and to use the right formula with KCL.
Only knowing Sum of I In = Sum of I Out
Thanks a lot and nice day.
jm
1st question:
2nd question:
jm
