Basic Engineering Circuit Analysis 10th Ed., Problem 2.87
jbates
Joined Feb 2, 2011
3
I've been playing around with this problem for a couple hours. I think it might be impossible, so asking here is my last resort.
Rich (BB code):
            + 5V -
 |-------|----R----|-----|
4kΩ   Is/|\       6kΩ   3kΩ
Find Is. Is is a current source, btw, in-case my text-art isn't clear enough.
First, I did the obvious and combined the two rightmost resistors into a 2kΩ equivalent resistor.
Rich (BB code):
            + 5V -
 |-------|----R----|
4kΩ   Is/|\       2kΩ
From the perspective of the node above Is, that leaves two paths to the node below Is where the voltage drops should be the same. Calling the current counter-clockwise through the left loop I1 and clockwise through the right loop I2, Is = I1+I2 and
5V + I2*2kΩ = I1*4kΩ
I've tried a million different things from this point, but I just can't solve for Is. I don't think it's possible. This is a new edition of the book and I think this problem must have a typo somewhere.
jbates
Joined Feb 2, 2011
3
It's a resistor but the resistance isn't given, only the voltage across it.
So it really can't be solved with the given information?
Jony130
Joined Feb 17, 2009
5,487
If R is unknown, the only think you can do is this
Is = I1 + I2
I2 = 5V/R
I1 = ( 5V + ((5V/R)*2K) ) / 4K
Is = 5V/R + ( 5V + ((5V/R)*2K) ) / 4K = 5V/R1 + (5V + 10K/R1) / 4k =
= (6000 + R1) /(800 * R1)
steveb
Joined Jul 3, 2008
2,436
I agree. You need to find Is as a function of R.
It's obvious that the value of R is needed because if R=0, there is no solution (Is goes to infinity), and if R is very large then current through R is negligible and the current source has 5V across it resulting in 5V across the 4K resistor and Is is 1.25 mA in the limit as R goes to infinity.
